how do skunk 2 stage 2 turbo camshafts perform with 20+ psi
As the title states I searched all night and can't find anything.
This is specifically for the skunk 2 stage 2 turbo cams.
Are they better than itr cams at least? will the give great gains over itr?
Maybe nobody replied because you made 5 post's on the subject in a 6hr period...
Too much cam for you, I would do ITR's or Tuner1's. Pro-1's are the biggest you should run if you had a bigger turbo, so Pro-2's arent your route.
Time is of an essence at the moment please explain why it is to much I was under the impression it wasn't enough
This subject is whipped to death on this forum weekly, a simple search in the 5hrs since you made this thread would of returned a plethora of information. I took the liberty of finding 2 for you real quick... Evans-Tuning has done plenty of Pro Series testing as well.... Turbo's smaller than a GT35R do not do well with cams the size of Pro-1's, so Pro-2's wont be any better.
https://honda-tech.com/forums/showth...highlight=pro1
Just called skunk2 aswell those links I have read they glorify the pro 1s I was specifically looking for reviews and people who have used these shunk2 stage 2 turbo cams thanks for your help I have determined that these turbo camshafts are to small for me and not too big as you stated in your last post thank you tho
Do not use Turbo Cams in a VTEC Head, you want to use all motor cams... but I am not going to go through why as this info is regularly available on this site as well.
I willƒ you seem to be immature and not knowledgable on camshaft application hope you have fun posting on my thread SON
All I wanted was info on these turbo cams nothing else. I will be going with a different set after I got the info I needed read my last post please
This specific forum has seen some dense individuals in the last few days, and I figured you were going to join them, all the info I gave you is factual... do with it whatever you wish.
Thats what I gathered after reading alot of threads as well. I ended up buying tuner 2 stage 2 cams for my turbo setup using bullseye S362 on a LS/Vtec, hoping it rips.
I was doing a perty extensive search on these cams I originally asked about and nothing but a pdf file came up no real info and I posted this thread in the early morning hours due to the fact that I had an opportunity to pick these up for my pro 2s, I called the manufacturer to recieve info before the deal was fullfilled, I may have been one of those dense individuals you speak of for trying to get some solid research on my end. I never asked about any other cam what so ever either so I was not trying to beat the dead horse thanks for your time, lets move on
phaphon
Jul 22, 2010 12:44 PM
