Upgrading cams... Got a few questions...
ok the motor is a JDM sir1 b16a...
With a big tube tri-y header
Skunk2 intake manifold
Omni 68mm TB
Skunk2 cam gears
full Greddy (not sure of model) 2.5'' exhaust.
Going to be upgrading from stock valvetrain to skunk2 pro 2's...
I know that your able to use the K series retainers and reuse the keepers, and thats my plan...
1) I have JG dual spings which I recived with the sale of the car BNIB... I have read many bad things about JG... Does this just go for his motors or all his parts???
2) Will the K series retainers work well with the JG springs or do they only work on certain dual springs???
3) Is there a how to out there for changing the valve springs and retainers with the head on using compressed air to hold the valves or a hanger threw the spark plug hole...
4) I know tuning will get more power out of my set up but, is tuning absoultely neccicary???
5) Is there anything else that I need???
Thanks guys...
Omni 68mm TB
Skunk2 cam gears
Thanks guys...
If you've heard JG has bad parts you should probably get something with a better reputation.
And yes, tuning is absolutely necessary. You can probably also sell that skunk2 IM if you would like to. It's not worth it's weight in salt.
hondatech8798
Jan 5, 2013 11:11 PM
JDMAF
Feb 28, 2011 06:23 AM
Mattb16teg
Oct 30, 2008 07:12 PM
