99 Si salve cylinder fell apart, help!
I'm removing the transmission on my 99 Si in order to replace the clutch. When I was removing the slave cylinder, the plunger/boot fell off from the slave cylinder. Is this normal or should I replace the slave cylinder?
Thanks.
Thanks.
some fluid came out, but not much. The car has 130k miles, so im sure it's the oem unit. If it's not expensive, I might just replace it now. I recently replaced the master cylinder as well.
-BlueGSR-
Dec 21, 2002 07:30 AM
You'll know if you need to replace it soon.
