89 crx dx fuse/relay problem
I recently did a jdm d15b swap in my crx, also did a full wiretuck. i hooked the battery up aand it was dead so i put a buddys charger on it. 50A engine start turned the key and the main relay sounded like a spun rod bearing. Gauge cluster lights went out, also no turn signals, i do have tail lights and brake lights, the only thing working in my cluster is the high beam indicator. I checked all the fuses and still have nothing, made sure everything was plugged in for the dash and the dash is grounded above the steering column. Everything was working prior to me putting his engine stater on. Im thinking its a relay problem however i do not know what relay or if there is a relay that controls signals as well as gauge cluster. Any help would be greatly appreciated
mugenwannabe
12
Sep 22, 2019 04:48 PM
slammin86
Oct 13, 2007 08:02 PM
premo_si
Aug 5, 2006 10:07 AM
