antifreeze leak on 99 gsr
Old Feb 26, 2011 | 06:45 PM
hondapowerb18c1's Avatar
Default antifreeze leak on 99 gsr
does any one have any idea on where my antifreeze leak is coming from? it drips from back side of motor down the back of oil pan. car did sit over winter pulled it out last week and parked it in driveway after driving 10 miles back home. i shut the car off and then saw a puddle under it when i came outside 30 min later any ideas would be awesome id appreciate it
Old Feb 26, 2011 | 06:59 PM
djkobe's Avatar
Default Re: antifreeze leak on 99 gsr
have you checked all the hoses? such as heater core and other coolant hoses? my DA has the same problem currently and when i had it on the lift today there was a small 1/4" hose underneath the intake manifold that had coolant drips coming down from it so i tightened the clamps and it still leaks so i believe it may be in need of replacing.
not sure if that helps at all but it may give you a start. my best advice is to double check all clamps and if their tight just start replacing hoses or all of them. you can never go wrong with new hoses.
Old Feb 26, 2011 | 07:00 PM
MD426's Avatar
Probably from the water pump or line leading to the heater core. Top off the anti freeze and warm up the car, turn on the heat and watch on look at all the hoses for the cooling system.
Old Feb 26, 2011 | 07:05 PM
ok thx guys ill check those tomorrow n ill post on what i find out thx again guys
Old Feb 26, 2011 | 07:09 PM
oh and another thing my top radiator hose gets too temp but the but line stays ice cold would that be the stat. or heater core problems? thx again
Old Feb 26, 2011 | 07:47 PM
fcm's Avatar
fcm
Old Fart
The but line? 94
Old Feb 26, 2011 | 07:51 PM
sorry...coming from the radiator the top antifreeze line gets to temp, but the bottom line stays ice cold
scottyb2fast
Aug 7, 2014 10:14 PM
Gsrsi
Jan 3, 2012 11:49 AM
2kgsrt
Apr 5, 2010 09:00 PM
JSpekBB4
Jan 23, 2007 09:09 PM
DC2LsVtec
Jun 23, 2003 11:52 AM
