ABS Light & Noise in clutch.
Old Feb 26, 2011 | 04:07 PM
Jwinnd88's Avatar
Icon2 ABS Light & Noise in clutch.
Alright I just bought a 94 LS about a month ago. When I bought it the ABS light was on, couldnt figure out why? The car has a clean title, and one owner who did all the maintenance work on it. Also Im hearing a faint vibrating or humming noise when shifting from second to third. It only happens inbetween those gears, and it comes and goes. Any suggestions?
Old Feb 26, 2011 | 05:29 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ABS Light & Noise in clutch.
You can pull the ABS codes in the same manner as you pull a CEL.
Old Feb 26, 2011 | 07:57 PM
fcm's Avatar
fcm
Old Fart
Does ABS work?
Have you checked the ABS fuse?
Have you tried an ECU/ECM reset?
As mentioned, pull ABS trouble code. 94
Old Feb 27, 2011 | 06:14 PM
Jwinnd88's Avatar
Thanks both! Ya shortly after posting this I read the how to thread on pulling ABS codes. So I will check that out.
kbxer22
Honda Civic (2001 - 2005)
Dec 24, 2006 07:29 PM
JDAN
Nov 17, 2004 06:08 AM
n_stemp
Sep 21, 2004 07:47 PM
Warren
May 18, 2002 09:37 PM
