B18b 02 sensor wiring question
Old Feb 26, 2011 | 01:47 PM
j4s0n1337's Avatar
Default B18b 02 sensor wiring question
So, I'm a cheep bastard and I don't want to buy a new 02 sensor, the plug fore the harness is 1 wire and there are 4 wires on the sensor, is there anyway i could wire them together in order for my 02 sensor to function properly and I can pass inspection, or am I asking the impossible.
Old Feb 26, 2011 | 03:12 PM
94EG8's Avatar
Seagull Management
Default Re: B18b 02 sensor wiring question
You'll have to run the other 3 wires. Otherwise you're going to throw an O2 heater sensor code.
Old Feb 26, 2011 | 04:12 PM
honda.lioness's Avatar
Is the ECU for your Civic OBD-0, OBD-I or OBD-II? If your (1-wire O2 sensor) harness is matched to your ECU, then maybe you can do what this guy did:
http://groups.google.com/group/alt.a...f3fec47a163f6#
Old Feb 26, 2011 | 04:53 PM
94EG8's Avatar
Seagull Management
I'm guessing (and guess really is the right word here since the OP never mentioned what year the car was (or even what the car was) or the year of the engine) that the OP has a '92 - '95 CX (only '92 - '00 Civic to come with a single wire unheated O2 sensor) All OBD1/OBD2 Integra ECUs look for a 4 wire O2 sensor.
You're totally right about being able to use a 4 wire heated O2 sensor with an ECU that looks for a single wire O2 sensor though, a lot of guys running D15B Vtec swaps with the proper P08 ECU do that.
Old Feb 27, 2011 | 02:51 AM
j4s0n1337's Avatar
PR4 OBD1 ecu, it's a 95 jdm b18b, It's the only thing holding me back from passing inspection, I might try that idea 94eg8
Old Feb 27, 2011 | 04:43 AM
HondaPartsHero's Avatar
Technical Hero
I think the problem with that idea above, unless I'm missing something, is that the ECU will still be looking for the heater circuit thereby throwing a CEL. If your state doesn't care about check engine lights for OBD1 you'll be in the clear. This trick will make the O2 function and will pass visual but you'll still have a CEL unless you can trick the ECU somehow.
Old Feb 27, 2011 | 05:16 AM
94EG8's Avatar
Seagull Management
OBD1 PR4 looks for a heated O2 sensor, you're going to have to add the other 3 wires, see pic below:
Old Feb 28, 2011 | 09:42 AM
j4s0n1337's Avatar
I don't have vtec though, Would it still work since I can't add those extra two wires from the picture on the left? I just want the CEL to go away so I can pass inspection
Old Feb 28, 2011 | 11:10 AM
j4s0n1337's Avatar
BUMPPPPPPPPP
Old Feb 28, 2011 | 11:41 AM
94EG8's Avatar
Seagull Management
Yes it'll work, ignore the vtec wiring part.
phbrush
27
Dec 17, 2014 07:25 AM
crxsi814
11
Jan 17, 2011 10:57 AM
tomek5x
Jan 21, 2008 09:56 AM
Terabass
Jan 24, 2007 07:27 PM
PuiPui
Jan 8, 2005 02:50 PM
