Suspension & Brakes Theory, alignment, spring rates....
How do you lower your car without sacrificing ride quality?
Old Feb 26, 2011 | 12:13 PM
Romo Pyro's Avatar
Default How do you lower your car without sacrificing ride quality?
What kit, spring/strut combo could you use? I'm looking for a mild drop but I do NOT want it to be uncomfortable. My car now has koni yellows and gc's (450f/400r). And it's a nightmare around town. I want my next car to look good but ride nice. Any ideas?
Old Feb 26, 2011 | 02:40 PM
STOCK_SOHC_DX's Avatar
Default Re: How do you lower your car without sacrificing ride quality?
Keep your Koni's and get Eibach pro's
Old Feb 26, 2011 | 09:42 PM
soybeanbaby's Avatar
any suggestions on a good website to buy some at a reasonable price?
Old Feb 27, 2011 | 05:24 PM
96hb's Avatar
Keep the Koni's, raise the car up some and/or get a softer spring. If you don't care about adjustability, get a set of quality lowering springs, like Eibach or H&R. They will be MUCH more comfortable than GC's.
Old Feb 27, 2011 | 08:21 PM
alphalanos's Avatar
how much you want for the GCs?
Old Feb 27, 2011 | 09:07 PM
93eg*machine's Avatar
I kept my ride slammed and I take a longer route to work but it's alot smoother and as far as driveways and speed bumps I go around and try to find a better exit but sometimes you just gotta go into battle with those bad boys. . .
Old Feb 27, 2011 | 11:07 PM
98civdx's Avatar
Master Detailer
What in the world does this have to do with what he asked??
I agree with solbrothers..
That or you can try and find drop forks, and pro arms form ST.
Old Feb 28, 2011 | 05:25 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Keep the Koni shocks, set the circlips/perches to the lowest setting all around, put your stock front springs back on, and find some OEM ITR rear springs to even out the ride height.
I went through the exact same scenario as you back in 2005 - I had Koni/GC with 380/450 rates and a 100 mile commute. Sucked. So I did the above and have been riding this way nearly 6 years now. It rides a touch stiffer than stock due to the stiffer rear ITR springs, but nowhere near the harshness of stiff@$$ coilover springs.
Old Mar 1, 2011 | 01:45 AM
92civiceg9gsr's Avatar
^^^This^^^
ef 4dr
Suspension & Brakes
Dec 25, 2007 05:42 PM
dornon13
Suspension & Brakes
26
Nov 14, 2006 06:42 PM
cambopheonix56
Suspension & Brakes
Oct 31, 2006 07:36 PM
slow_ls
Suspension & Brakes
Aug 22, 2006 08:45 PM
Team Underground Teg
Dec 29, 2004 06:22 PM
