car jerking after engine swap.
i recently swap a b16a2 into my EF sedan. after everything done, the car sounds like it has launch control at 1000-2000rpm range. spark plugs, distributor, etc has been check and everything is fine. the only thing i didn't check is the ECU because i do not know how to. it is almost impossible to be driven slowly. ECU is from an EG8 modified to suit the car. at other rpm, the car runs perfectly. need advice and suggestions to solve this problem. any help is very much appreciated.
converted to obd2 already.. i suspect its the ECU being faulty. coz when i plug in a friend's to run a test, it's fine.. if it is the ECU, what is wrong? tuning? components? i'm a beginner builder and i suck at electronics stuff..
ouw.. haven't thought of that.. but i went for a dyno session and realize that there is too much fuel on low rpm range.. could that cause this problem?
