big brake kits
Old Feb 26, 2011 | 06:05 AM
vtakyo94's Avatar
Default big brake kits
I have to get a new set of calipers in the rear of my car and while im at it im just do the fronts aswell with a big brake kit but i can't seem to find any upgraded big brake kits for the rears aswell as fronts. any suggestions on websites etc or a good company would be greatly appreciated.
Old Feb 26, 2011 | 06:14 AM
94VTEC2TONE's Avatar
Default Re: big brake kits
fastbrakes.com. or go to brakeexpert on honda-tekh
Old Feb 26, 2011 | 06:22 AM
VVENOM800TT's Avatar
Wilwood have a single piston bbk for the rear
Old Feb 26, 2011 | 10:05 AM
Murk 'EM's Avatar
Just get factory type r breaks cheaper and if your asking this question you probably don't have the power under the hood to even need a bbk
Old Feb 27, 2011 | 05:02 AM
vtakyo94's Avatar
not yet. im staying away from a full build till i have a good set of brakes and suspension taken care of. everrything im buying now is in preparation for a heavy build.
Old Feb 27, 2011 | 07:30 AM
Murk 'EM's Avatar
Honestly big break kits are for ricers how big you wanna go cause you have to look at a bigger wheel size like probably 17s to fit around the calipers..
Either way there's no need for that kit me n the team I used to roll with had a hatch with 650 whp and we were running itr breaks with drilled rotors and they held up just fine and still able to run 15 16s and look good
Old Feb 27, 2011 | 08:36 AM
vtakyo94's Avatar
well some of the wilwoods you can still run 16's. im not looking for anything too crazy. the trend is seeming to lean towards the itr calipers and just buy drilled and slotted rotors. im not hard on the brakes so i dont have to worry about cracking.
Old Feb 27, 2011 | 10:58 AM
Murk 'EM's Avatar
Its cheaper and it'll get the same job done
Old Feb 27, 2011 | 05:23 PM
the wilwood kit is about $1000 on their site, im sure you can get it cheaper if you shop around.
Old Mar 3, 2011 | 12:37 PM
vtakyo94's Avatar
yeah i can but i can also get new type r calipers for even cheaper.
Old Mar 3, 2011 | 03:43 PM
haha but the wilwoods are 4 or 6 piston depending. and huge one piston for the rear kit.
Old Mar 3, 2011 | 03:47 PM
Murk 'EM's Avatar
But you don't need 4 or 6 pistons its over kill and too expensive along with the rotors you need to run and the pads.. Just too much over all for what you can do with oem
Old Mar 3, 2011 | 04:10 PM
Well if thats to much then stick with type r calipers, i was just giving you a suggestion
Old Mar 4, 2011 | 10:22 AM
vtakyo94's Avatar
yeah i appreciate the suggestions. i've heard oem can handle alot. type r calipers on a gsr is a little extra work. researching on it i have to machine the caliper bracket down 3mm so it doesn't rub because the type r 5 lug sticks out a little further than the gsr caliper OR convert the whole spindle to the type r 5 lug.
Old Mar 4, 2011 | 10:01 PM
Scooooter7's Avatar
Just keep the OEM brakes and drive it like a grocery getter. LOL
Old Mar 5, 2011 | 12:57 AM
fastrxu's Avatar
Search for " x brakes on y car" here on htech or google it with the word integra or civic in the search
A lot of oem options even two piston acura legend gs brakes with 11 inch prelude rotors just a little machining needed. But a machine shop will do it for 20 bucks
Old Mar 5, 2011 | 04:42 AM
vtakyo94's Avatar
yeah that's what i mean. the common thing is taking 3mm off the back of the bracket to fit. not too hard. waiting for the tax return money before i start buying up all the stuff im gonna need.
Old Dec 12, 2011 | 05:06 AM
omelchor92's Avatar
agree on cross drilled on gs brakes it works fine
Old Dec 12, 2011 | 05:37 AM
00IntegrAllmotoR's Avatar
HT Black OPs
BBK should be a last resort if anything,
Try better pads
Better lines
Better fluid
Ducting
Refurbished calipers
The rears dont even need to be upgraded, just replaced in ur case.
Old Dec 12, 2011 | 06:06 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
Upgrade what you have, rebuild or replace with stock calipers, replace brake lines with braid SS lines, upgrade the rotors and pads, [Power Stop rotors Hawk brake pads] upgrade brake fluid.
After that the limiting factor will be the tires, the brakes will outperform any tires you put on the car, spend the money you save on better tires and suspension components. 94
murphy95si
Suspension & Brakes
Mar 24, 2013 06:28 PM
gosu08
Nov 28, 2009 02:22 PM
reptar_head
Oct 10, 2007 06:34 AM
intxactdgsr
Oct 19, 2005 02:03 PM
94gsrIntegra
Sep 13, 2004 07:22 PM
