96' Integra bouncing tach problem.
Old Feb 26, 2011 | 02:05 AM
drewman12's Avatar
Default 96' Integra bouncing tach problem.
Ok so my tach has all of the sudden started to act up! It will randomly start bouncing above 2500 rpm then when i drop rpms back down it does right back into position and works fine... Weird. I know its not the distributor because there is no loss in power at all and the one in it only has about 4k miles on it. any help appreciated!
Old Mar 2, 2011 | 06:05 AM
::ek-4::'s Avatar
Default Re: 96' Integra bouncing tach problem.
If you have any friends with an integra borrow his cluster. Could be that. Good luck.
Old Mar 3, 2011 | 06:44 AM
ilovuall's Avatar
the tach wire is either loose on the ignition control module or the icm is bad.
Old Mar 3, 2011 | 05:44 PM
PyroProblem's Avatar
+1 for ICM failing...Is this "new" distributor aftermarket by chance?
Seen this a few times before...
Old Mar 3, 2011 | 05:51 PM
mike schram's Avatar
mine does the same thing and its in a 94 ls teg. i have swapped clusters. ran jumper wires. and also swapped distributors and internals. the only other thing i have found is if you get mad and kick the underside of the center kick panel it will work for a few so im guessing intermitent wiring short or loose wire but i cannot recreate the bouncing tack by wiggling wires or connectors so if you figure somthing out let me know
Old Mar 12, 2011 | 11:23 PM
https://honda-tech.com/album.php?alb...ictureid=67448
Old Mar 17, 2011 | 10:02 PM
W!d3b0dYr3X's Avatar
My crx did this before. Turned out the alternator was loose and screwing with the power. My gauge staryed acting up and after a while the car died.
Old Jul 31, 2011 | 08:54 AM
System Lord's Avatar
I have a similar issue im thinking ima try that cluster idea
soad1234
Aug 19, 2007 01:45 PM
Scubster
Oct 13, 2004 12:20 PM
b18c5hatchie
Jul 2, 2004 06:59 PM
skunktuned
Jun 29, 2004 02:33 PM
DCx2xNV
Mar 4, 2002 10:45 AM
