some used parts i have left over
Old Feb 25, 2011 | 07:45 PM
92lxsleeper's Avatar
Default some used parts i have left over
cleaning up my shed and heres some stuff i'd like to get rid of.
D15b7 rotating assembly
d15b7 cylinder head
non vtec obd1 dizzy (off the d15)
crank pulley for ex, has 3 sections for belts
stock flywheel, never resurfaced. good condition.
autozone clutch with pressure plate 500 miles on it
D series intake manifold, looks like a b7 manifold but is stamped P 1 0 in the back, not P06 or P28. possibly jdm? idk.
P06 (5 speed) ecu never tampered with
DX 5 speed tranny, no grinds or pop outs, has newer axle seals
and last but not least my rebuilt ls bottom end.
b18b1 with beck arnley main bearings, clevite rod bearings. ARP main studs, ARP rod bolts, stock pistons/rods. includes dissasembled head, valve train if u want it, cams, all bolts and intake manifold. i do not have the valve cover for it, and i can include a d16 throttle body for it.
send me some prices and everything can be shipped except the d15 block, the tranny, and the ls motor.
if you want to pick up the motor or anything else, my zipcode is 02865. Lincoln, RI
Old Mar 13, 2011 | 06:53 PM
goulddh's Avatar
Default Re: some used parts i have left over
I am interested in the tranny. Are you sure you can't ship it? I think it is light enough to go regular UPS ground.
Z0831xiz
Engine Machining & Assembly
Aug 29, 2016 08:31 PM
H-allmotorda9
Mar 13, 2010 05:08 AM
skr33t_rac3r
Mar 31, 2008 12:17 AM
JadeGreenEF9
Dec 7, 2006 04:37 AM
made in JAPAN
Jun 11, 2004 11:46 AM
