Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake pad installation -- any tips?
Old Sep 25, 2002 | 08:57 PM
TRE_'s Avatar
Default Brake pad installation -- any tips?
I've replaced pads before but it seems like everytime I have I've replaced the rotors at the same time! I just got my axxis pads in from andie and plan on installing JUST the pads. I have a pretty good idea as to how to do it w/ out taking off the rotor, but I'm just looking for some tips/pointers. Maybe so the process wont take too long!
Thanks guys, your always a huge help!
BTW, the car is a 92 civic dx, sedan.
Old Sep 25, 2002 | 10:51 PM
Civic242's Avatar
Default Re: Brake pad installation -- any tips? (Evasive Tuning)
Always use use Anti-squeal lube between the shim and pad.
Always have a fresh can of brake cleaner for pads and rotors.
Apply caliper lube to slides on calipers so pad won't stick.
Pump brakes to lock up before moving your car.
Old Sep 26, 2002 | 06:13 AM
TRE_'s Avatar
Default Re: Brake pad installation -- any tips? (pineapple)
Cool, thanks for all the pointers guys! Hopefully everything goes smoothly.
Old Sep 26, 2002 | 06:20 AM
Civic242's Avatar
brake cleaner can be sprayed on all parts of the brakes including pads and caliper?
everything? i dont know so im asking.
Yeah you can and you need to do this to remove all finger oils and greases from the rotors and brake pads before you put it all parts together. It also cleans out the dirt in the caliper piston rubber baffel for smother operation.
Old Sep 26, 2002 | 06:25 AM
Crazydave's Avatar
Default Re: Brake pad installation -- any tips? (Civic242)
let them cool off before changing them..
brake parts get really hot
inspect your brake lines when working on them
don't let your caliper hang by the brake line
if you see black spots (little those on a cheetah) then your HAVE to replace your rotor, maching it won't fix it.
bleed/flush your brakes
clean up brake fluid quickly.. it eats paint
Old Sep 26, 2002 | 09:37 AM
ITC Racer's Avatar
Default Re: Brake pad installation -- any tips? (Crazydave)
Lots of good suggestions but I would not turn rotors for any AX/Track use/Road Racing application since this removes material from the rotor which will not allow the rotors to absorb as much heat and will make the rotors warp/crack sooner.
If changing to a different brake lining material, you may want to take a scotch brite pad to the rotor to clean the old pad material off but I would not worry about it. It will just take a little more time for the pads to break into the rotors.
Good luck
turnsignalandy
Nov 12, 2006 03:35 AM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
hrc_385
Sep 12, 2004 02:11 PM
GQ Cowboy
30
Jan 3, 2003 12:39 AM
timbuktu
Mar 22, 2002 12:50 PM
