Upper strut bars.
Old Feb 25, 2011 | 10:28 AM
jlhobdey's Avatar
Default Upper strut bars.
just curious does anyone know of a reason not to build your own upper front and rear strut bars. I looked online and they are pretty steep in price.
Old Feb 25, 2011 | 10:48 AM
Tyson's Avatar
Default Re: Upper strut bars.
Fine if u can weld. Shrug
Old Feb 25, 2011 | 10:52 AM
jlhobdey's Avatar
Not the best welder (I'm OK).. but I know one of the best. My grandpa welded on damns for years heading up there in a month or so.. I should have the metal cut and everything ready by then. thinking of a 3 point front, and 4 point rear.. Thanks..
Old Feb 25, 2011 | 12:48 PM
prelude182's Avatar
if you can do it why not? i wish i had some fabrication skills cause my car would be stiffer than a frozen hot dog.
Old Feb 25, 2011 | 01:55 PM
Tyson's Avatar
I'd skip the 3 pt to the firewall, its not much of a reinforcement. Fender braces would be much more effective.
And I don't see a point in bracing the rear shock towers. There's not much going on back there.
Old Feb 25, 2011 | 02:22 PM
jlhobdey's Avatar
thanks! I'll take that advice
Old Feb 25, 2011 | 02:24 PM
jlhobdey's Avatar
It will likely be a bit.. couple months till I visit the welder (my grandpa) but I'll post pics when it is made
Old Feb 25, 2011 | 03:30 PM
Tyson's Avatar
I'd copy the password jdm design. Its the most straight forward way. Box the top of the strut tower and weld a beam between.
Old Feb 25, 2011 | 03:51 PM
night's Avatar
ya know, they do call these strut bars and I've read they help more with struts than shocks.. anyone that can comment on that?
Old Feb 25, 2011 | 04:21 PM
Tyson's Avatar
read my thoughts here.
https://honda-tech.com/forums/suspension-brakes-54/installing-strut-brace-2876238/
Old Feb 25, 2011 | 08:28 PM
night's Avatar
ahh, good thread. I'll put that in the road racing faq. I don't always check that forum for the load of general questions.
I have struts in the rear and that is more than good enough talk to convince me to put one back there.
Old Feb 25, 2011 | 08:51 PM
blaak-crx's Avatar
Old Feb 28, 2011 | 09:16 AM
jlhobdey's Avatar
My fiance has class late tonight.. so after work going to get started on building one.. I also need to move the fuse box some to accomadate it nicely. I was originally going with the NGR design.. Looked at the Password JDM one and they look the same.
Old Feb 28, 2011 | 11:04 AM
4drEF's Avatar
Keyboard Humorist
Fender braces + 3 point shock tower to firewall bar = winner! (as long as the 3 point gets into something solid and not just flimsy sheet metal firewall)
That ties in all sorts of flex vertically and horizontally.
journeyquest
Aug 22, 2010 02:26 PM
2000HondaEm1
Sep 12, 2009 03:12 PM
ES1dvr
Honda Civic (2001 - 2005)
May 8, 2007 11:07 PM
ITR607
Oct 27, 2001 02:37 PM
