Honda S2000 Honda S2000
whats up guys got 06 s2000 today
Old Feb 24, 2011 | 07:53 PM
miguel329's Avatar
Default whats up guys got 06 s2000 today
hows it going guys just wanted say whats up, i picked up a 06 s2000 with 28,000 miles fun car. will take pics in am. rides great. what kind of fluid you guys using in the trans? going change all fluids even though dealer said they did it lol.
Old Feb 24, 2011 | 11:51 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: whats up guys got 06 s2000 today
For the engine, I would recommend oil. People will tell you that you should get your boutique oil from NASA's research lab. I get it from walmart on sale. My car runs just as good.
I use Honda MTF in the trans. Works great. It's $7 per bottle from the dealer.
I use AMSOIL in the diff. IDK...seems fine. It's oil. It's all the same ****.
Old Feb 25, 2011 | 12:57 AM
hondafreak95's Avatar
Cant go wrong wit Honda MTF or Amsoil.
Old Feb 25, 2011 | 03:15 PM
miguel329's Avatar
ok thanks alot.
Old Feb 25, 2011 | 04:24 PM
frogsr's Avatar
differential - le1605
transmission - honda mtf
Old Feb 27, 2011 | 02:15 PM
Rtzx9r's Avatar
GDD 1%
I used honda fluids in my tranny and rear end. Forget as its been a few years and 10k miles ago. Engine is mobil 1 synthetic.
Old Feb 27, 2011 | 04:20 PM
Ruckus2009's Avatar
Is this post goin to get LOCKED because there isn't any tech in it?
Old Mar 1, 2011 | 06:17 PM
Deception8's Avatar
I used Redline MT90 GL4 in the trans last time, Mobil 1 GL5 gear oil in the diff. No issues, MT90 shifts like buttah.
Engine has always been Castrol Syntec 10w30, 40 weight in the hotter months w/ turbo.
Have read a lot of posts about Mobil 1 motor oil burning in S2k's so I would not recommend that
Old Mar 2, 2011 | 11:35 AM
92HB_HB's Avatar
if ur on a budget, just go pick up some Wesson oil at the grocery store.
Old Mar 2, 2011 | 11:39 AM
00siboy's Avatar
i use mobil1 synthetic in my em1 cuz its recommended for hondas, but it does burn alot, would castrol be better? (sorry to threadjack)
Old Mar 2, 2011 | 06:31 PM
Deception8's Avatar
Cant say for sure but Id give it a try, they are about the same price. Personally Ive never had a problem w/ Castrol Syntec or Castrol Edge
Old Mar 3, 2011 | 06:09 AM
White Smoke's Avatar
i my honda
Global Mod
What Id recommend ideally, but there are many other options.
Old Apr 6, 2011 | 11:27 PM
miguel329's Avatar
Thank you will be changing fluids in diff and trans soon.
Old Apr 7, 2011 | 05:47 AM
sextav6's Avatar
Correct me if I'm wrong, but Honda doesn't make/sell a gear oil for the rear diff.
I second the LE for the diff and Honda MTF for the trans, I personally use Amsoil in the motor.
Old Apr 7, 2011 | 06:09 AM
realmike15's Avatar
From what I've seen Honda MTF is highly recommended for the tranny.
I'm having my tranny fluid, rear diff. fluid, brake fluid and air cleaner done today. I asked the shop to use Honda fluids for everything. I like to think Honda fluids are designed for their cars (wishful thinking?) and since they're not overly expensive... I see no reason to use anything else.
Old Apr 8, 2011 | 10:01 AM
sextav6's Avatar
you might want to verify what kind of fluid they used in the diff because Honda doesn't sell a fluid for the s2k diff
Old Apr 8, 2011 | 01:48 PM
Slammed-Vr6's Avatar
still learning how to use diz
Old Apr 8, 2011 | 02:28 PM
Boots's Avatar
they have a fluid which they put in the transfer cases and diffs of pilots, cr-v's, and ridgelines and its a 75-90w...last time i spoke to honda that's the same fluid they call for in the diff's of s2k's as well...now that's not what i do, because i think you can always improve on O.E., but that's what the manufacturer calls for
Old Apr 8, 2011 | 10:35 PM
Froth's Avatar
Honda does not sell/manufacture any gear oil manufactured by them for their Differentials unless they take VTM-4 which is their special Active Torque LSD fluid in the Pilot and Ridgeline, I have on high authority(from seeing dealer services being performed, Friends who worked for Honda) that the OE fluid is Castrol 75w90 or another Named brand fluid of the 75w90 weight. Honda does not make a 75w90. The same is true of MANY manufacturers including Toyota whom I work for and they as well use Castrol 75w90 in Differentials.
If you put VTM-4 in an S2000 Differential and drove it, you are going to blow it up. It is entirely too thin and has additives not needed by the S2000 diff.
For me:
Engine - Valvoline Synpower 10w-30 (With Blackstone Labs tests to back it up)
Transmission - GM Synchromesh (112k and Shifts like it was made yesterday)
Differential - Amsoil 75w90 Severe gear Synthetic (Changed every 10k, no whines no noise, no issues at 112k)
-Froth
Old Apr 9, 2011 | 05:44 AM
Boots's Avatar
im not going to argue with you, but unless they just recently stopped, honda had a 75-90, i've seen it before...when i worked for kia, we had our own diff fluid we used, so i would think honda, being much more sucessful would have their own as well
Old Apr 27, 2011 | 11:25 AM
sextav6's Avatar
they may source it, obviously they have to to service vehicles, but i was under the impression that honda didn't sell a gear oil that was ok for use in the S's diff. as noted above, the stuff for the crv has additives in it that is bad for the lsd.
i personally use the LE607, but that was before hardtopguy stopped selling it
bishwei
Dec 13, 2015 10:55 PM
rachjohns3350
Apr 23, 2013 12:14 PM
dc4_wHORE
Honda S2000
Oct 18, 2009 03:51 AM
mrivera
Southwest
Jan 16, 2008 07:52 PM
revvin9k
Mar 23, 2006 07:26 PM
