B16 Idle Issue
Old Feb 24, 2011 | 07:44 PM
1991civicb16's Avatar
Default B16 Idle Issue
I have narrowed my idle problem down to possibly my IACV, and i got a resistance reading of 3.1 ohms. I want to know if someone on here with a b16 can help me by getting the resistance of there IACV so i can be 100% sure. Thanks in advance.
Old Feb 24, 2011 | 08:25 PM
crx_si-r's Avatar
Default Re: Need a fellow b16 owner
Why not look in the shop manual? I'm pretty sure it states in there what acceptable readings are allowed to be considered functional.
Old Feb 24, 2011 | 08:51 PM
Former User's Avatar
I'll try to add more information to this thread as I was trying to help the OP at another forum. He has a 91 Civic with a 88-91 JDM b16a swap running on a chrome chipped P28. It has a surging idle problem. The FITV, ECT sensor, and TPS appear to test fine. The 88-91 Civic manual says their stock IACV should have a resistance of 8-15 Ohms. The OP's IACV reads 3.1 Ohms. The problem is that we don't know whether the IACV on his B16a and that of 88-91 Civics have the same resistance specs. Does anyone know the answer?
Old Feb 24, 2011 | 09:22 PM
crx_si-r's Avatar
i personally have run both D-Series and B-series IACV's on my LSV. no issues at all (untill it goes bad at one point or another). even now that i am fully converted to obd1, i am running an obd0 LS IACV on my 1st gen skunk2 manifold.
Old Feb 25, 2011 | 08:17 AM
zrickety's Avatar
are you measuring between the iacv pins with the plug disconnected? it should be in that 8-15ohm range. my b16 iacv is at 13.1 ohms. what is the issue, CEL?
Old Mar 18, 2011 | 07:51 PM
Got roaming idle. When i start it and leave it running without touching the gas pedal the idle will sit a 1k. The second i touch the gas pedal and it is fully warm the idle bounces 1k-1.5k and so i am trying to trouble shoot the reading to see if the iacv i got from the wrecking yard is bad to, and yes i was testing the iacv prongs not the plug. Also no there is no CEL.
andyc_0652
Oct 18, 2010 11:37 AM
civc_tt
Jul 20, 2006 06:54 AM
Passaudi1.8t
Feb 5, 2004 07:27 AM
