strange idle and temp gauge issues 91 da
Old Feb 24, 2011 | 07:15 PM
702 da tuner's Avatar
Default strange idle and temp gauge issues 91 da
i have a 91 da b18a1 completely rebuilt to stock specs. the car warms up and idles fine but after driving for about 10 minutes the temp gauge will shoot all the way hot and stick there. if i tap the dash above the gauge it drops back down to normal temp. i switched all the gauges out of my 92 da and they worked fine in that car. at the same time as this happens with the temp gauge my motor will idle up 100-200 rpm and then drop back down no matter what rpm the motor is at. i dont get a check engine light or any codes off the ecu. i would rather not take it to the shop im sure its an easy fix i just can figure out what could be wrong.
702 da tuner
Feb 25, 2011 11:12 AM
Frederick_Est87
Jul 25, 2009 10:05 AM
jdmstreethatch
Oct 25, 2006 01:26 PM
HondaTeg95
Feb 15, 2006 05:24 PM
eg92b16a2
Nov 29, 2004 09:50 AM
