swap H23A1 to a JDM H22A( motor mounts)???
Old Feb 24, 2011 | 06:56 PM
damdex's Avatar
Default swap H23A1 to a JDM H22A( motor mounts)???
hey guys i have a 93 prelude SR i had a H23A1 and the motor blew so i have just bought a JDM H22a DOHC V tec, i have already switched my H23 wire harness over i know about the wire for vtec and where they go but when i went to put the motor in the mounts didn't line up, the tranny was hitting the cross member under the fire wall, and the motor was sitting to high, where do i find these motor mounts or is it custom work i have to do?
Old Feb 24, 2011 | 08:57 PM
pprowler6's Avatar
Default Re: swap H23A1 to a JDM H22A( motor mounts)???
mounts are the same....
Old Feb 25, 2011 | 08:03 AM
snobordboy's Avatar
Moderator
Yup mounts are the same. If you are just looking at the top of the engine, the H22 head is taller, so it does stick up more. If you seem to have a mount issue, try using your H23 mounts, as they should be exactly the same on the engine, and you know they fit the car.
Old Feb 25, 2011 | 10:24 AM
damdex's Avatar
Is there a certain order to put in the motor like what mount do i start with and and finish with in order?
Old Feb 25, 2011 | 12:08 PM
minilogoguy18's Avatar
Bolt the rear mount to the subframe first, bolt the front mount to the subframe, bolt side mount to motor while out of car, same with trans mount, bolt rear mount bracket to engine/trans, drop motor/trans in, put through bolt in rear mount, bolt in the side mount and trans mount then bolt front mount bracket to block and put the through bolt through the front mount and you're done.
Old Feb 25, 2011 | 04:04 PM
damdex's Avatar
i'll try that thanx!
ChangoLoco
Dec 20, 2013 04:29 PM
Novtecdohc
Jun 24, 2005 01:16 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
Maengelito
16
Dec 5, 2004 07:07 AM
