H23a vtec camshaft?
Old Feb 24, 2011 | 02:57 PM
FreshCD5's Avatar
Default H23a vtec camshaft?
Ok I want to put skunk2 camshaft but what h motor should I use it from I was thinking of the h22a1. Are if there is any aftermarket company that makes them
Old Feb 24, 2011 | 04:56 PM
preludebro's Avatar
Default Re: H23a vtec camshaft?
huh? Ask your question again.
Old Feb 24, 2011 | 07:43 PM
Jmb106jr's Avatar
Originally Posted by FreshCD5
Ok I want to put skunk2 camshaft but but h motor should I use it from I was thinking of the h22a1. Are if there is any aftermarket company that makes them
Please read what u type before posting. Makes no sense! We are not mind readers here. Try again.
Old Feb 24, 2011 | 07:50 PM
nus_dogg's Avatar
Yeah, I don't quite understand where you're trying to get at. You can run the Skunk2 cam tuner stage 2 or Pro1; don't go any higher because you'll need higher compression to get it's full potential. You can run the Type S cams but from what I read, it'll cause premature wear due to the angle the valve sits if I remember right.
There's no significant difference on the H23A VTEC cams compared to the JDM H22A ones either. I say stick with Skunk2 cams. Power increase are great from Skunk2 cams.
Old Feb 25, 2011 | 02:16 PM
FreshCD5's Avatar
ok cool am going to get the skunk2 stage1 pro and sorry to say going to be in a automatic
Old Feb 25, 2011 | 05:17 PM
preludebro's Avatar
Put a F22 tranny to it. Bolt's right up.
Old Feb 25, 2011 | 11:43 PM
nus_dogg's Avatar
Huh? That's gonna slow him down cause of the long gear ratios.
Old Feb 26, 2011 | 12:21 AM
FreshCD5's Avatar
Am getting the whole h23 vtec auto swap I crack my f tranny 4 days ago I was not going to use it any way
Old Feb 26, 2011 | 10:00 AM
nus_dogg's Avatar
Good.
Old Feb 28, 2011 | 02:41 PM
FreshCD5's Avatar
Good.
do i have to do the spring retainers and valve train when i do the stage1 camshaft some told me no but if i do a stage2 i have to do it
austinwasthere
Jun 17, 2014 11:58 AM
orion840
Dec 28, 2007 06:08 PM
.I.Need.Money.
43
Feb 27, 2007 09:59 PM
tagperformance
Aug 15, 2006 09:10 AM
DC2 9K VTEC
Sep 20, 2004 07:55 PM
