help with questions about honing a block
Old Feb 24, 2011 | 01:41 PM
Built4Battle's Avatar
Default help with questions about honing a block
i was gonna replace the pistons rods and rings with a new oem ones
so if i get the block honed can i still use oem spec rings? or like 0.5mm bigger?
Old Feb 24, 2011 | 03:04 PM
1998GsRIntegra's Avatar
Default Re: help with questions about honing a block
If you go 0.5mm over you will need to get 81.5mm bore pistons and rings.
I dont think you really grasp the concept of what honing is. The machinist will only shave off a couple thousandths(probably spelled that wrong) from the cylinder walls to put on a nice cross hatched pattern for the piston rings to wear down when they are broken in.
Also, why are you putting in new pistons and rods? Unless you want to change the pistons for something with higher compression, just get new rings. As far as rods go unless its scored from running low on oil, or bent get new rod bearings. Same with the crankshaft, new bearings and you'll be good to go. No need to spend money you dont have to.
You will use standard 81mm bore pistons and rings providing all you do is have the block honed. Just check the gap on the rings when its assembled and make sure it is with in spec. All oem honda rings are gapped from the factory, so the likelyhood of you needing to gap them is slim to none.
ef4real
Honda S2000
16
May 15, 2014 06:23 PM
ITR.#1446
Jul 22, 2008 09:34 PM
b18ek670
May 2, 2006 04:54 PM
Robban26
15
Jan 24, 2004 01:31 AM
xteg95
May 3, 2003 10:56 AM
