Will i make atleast 350hp?
I currently make 230whp on 10psi with my greddy 18G on a stock d16z6 with 310CC injectors, 255walbro, and BnM FPR.
My rebuild list goes as follows:
Head:
Supertech valvetrain - valves, springs, retainers
Bisimoto 2.4 cam
Bisi cam gear
Having the head cleaned up, NOT ported or polished (cost issues)
ARP head studs
Not sure which head gasket to go with..
Bottom:
Vitara 75mm's
FJ I beam rods
Stock sleeves
Honed, notched, and hot tanked.
Turbo:
Greddy 18G, going to run a 5bolt vband to 3inch downpipe(i need some advice on the internal gate situation)
Edelbrock log mani
Large Greddy intercooler
HKS SSQV
750CC injectors
255 walbro
BnM FPR
Hallman Pro MBC
-talk to me guys, I've seen in super street a similar setup made 384hp with a T3/T4.
-also do i NEED to purchase the valves or can i clean up my stockers?
-lastly can i rev to 8500 with this setup?
Head:
Bisimoto 2.4 cam
Bisi cam gear
ARP head studs
Bottom:
Vitara 75mm's
FJ I beam rods
Stock sleeves
Turbo:
Edelbrock log mani
HKS SSQV
750CC injectors
255 walbro
BnM FPR
Hallman Pro MBC
You will make at most 350whp, that is the pretty much the max on the 18g. Also I know the internal wastegate has a pretty small flapper door, don't quote me but I think it's only around 32mm IIRC. I believe you can have it bored out though, again I have never dealt with internal wastegates so this is all what I can recall reading at one point.
I don't know D-series so I'm not sure about the revving of the motor or any other questions related to the motor.
small catch can w/ return and let your tuner determine the redline... id say 8200 as long as you have the springs and retainers...
u should be able to make that power however your going to be pushing that turbo... make sure that thing can breath...
