light wieght crank pulleys?
Old Feb 24, 2011 | 01:15 PM
accordmatt's Avatar
Default light wieght crank pulleys?
ok guys what are u feelings on lightwieght crank pulleys? like obx or unorthodox ones. l had one before but when l had to replace timing belt and take it off it started to crack around edges cuz it was made of thin aluminum. might have just been the kind l had but if anyone knows of a good strong one let me know
Old Feb 24, 2011 | 02:01 PM
nonvteclude's Avatar
Default Re: light wieght crank pulleys?
in my opinion they are not worth it. I would spend my money on something else.
Old Feb 24, 2011 | 05:01 PM
droe2001's Avatar
i have an obx that i have not installed yet, got it used in a trade, it looks solid but i dont know, it seems like the general consensus is that nothing that obx makes is any good. i was told on one thread that they have the a tendancy to break under load. i dont know if this is true or not may just be one guys opinion and lack of actual use but i would like to know what the chances are that i would be taking by using this on my turbo h22 setup
Old Feb 24, 2011 | 06:59 PM
q16racer's Avatar
Obx is junk. Period.
Old Feb 24, 2011 | 07:50 PM
accordmatt's Avatar
Well I have obx ps and alt pulleys there strong and work well. Unorthodox makes one also
Old Mar 14, 2011 | 04:42 PM
deltahuj's Avatar
I have set of UR for over a year no problems on my prelude
Old Mar 14, 2011 | 05:47 PM
accordmatt's Avatar
well mine l had no problems either until l had to remove it and it cracked trying to take off
accordmatt's Avatar
ur pulleys are like 200 bucks too
Old Mar 15, 2011 | 08:37 AM
q16racer's Avatar
euro r. S2000.
Old Mar 15, 2011 | 09:27 AM
accordmatt's Avatar
a s2000 crank pulley? is it lighter and better?
Old Mar 15, 2011 | 09:52 AM
Hawkze_2.3's Avatar
I've had an Unorthodox crank pulley for around 6-7 years now on my H23 and have not seen any issues.
Old Mar 15, 2011 | 10:41 AM
accordmatt's Avatar
the issue was not having it on the car and running it was removing and replacing it again. the lightwieght aluminum cracks easily when taking off
Old Mar 15, 2011 | 11:26 AM
Masterbobo's Avatar
my crank pulley is oem but i have the AEM pully kit and it has worked fine for 8+ years no probs.
Old Mar 15, 2011 | 01:27 PM
LUDEcidDream's Avatar
Originally Posted by q16racer
euro r. S2000.
do these have the same diameter?
you can get your stock one shaved down for much cheaper if you still have it.
Old Mar 15, 2011 | 01:29 PM
rash's Avatar
I have taken my Unorthodox pulley on and off at least 5 times now over the past 3 years with no issues.
Old Mar 15, 2011 | 02:49 PM
Hawkze_2.3's Avatar
Even if it was plastic, there's no reason it ever has to get hit hard enough to crack anything.
Old Mar 15, 2011 | 05:06 PM
accordmatt's Avatar
l dont have the fancy dancy crank pulley gear puller so l use pry bar. and the aluminum lip cracked on mine. it was a cheap bomz one but l think l will keep my stock one till l have the 200 bucks to spend on it
Old Mar 15, 2011 | 05:54 PM
q16racer's Avatar
you are wasting money on a crank pulley. put 200 towards something that will actually do something.
Old Mar 16, 2011 | 10:12 AM
jarol220's Avatar
I have an f20b one and it might as well be a light weight one because there is no power steering dive
Old Mar 16, 2011 | 05:17 PM
rjr162's Avatar
My brother (TurboLude97) has had one on his for years now. Never had an issue even with the HP he's putting down
Edit> Forgot to mention he has the UR pulley set
Nhull97
May 29, 2015 07:14 PM
djnikko
Mar 8, 2006 12:00 PM
zracer240
Jan 20, 2006 07:29 AM
Jason kiDD
Jul 16, 2003 02:47 PM
Vspec Sol
Apr 4, 2003 12:25 PM
