ASR/BEAKS on EK
So, i recently purchased ASR Subframe bar along with Beaks lower tie bar.
I am having an issue installing it my stock bolt the washer on it is too small so it goes through the hole on ASR Subframe bar.
The guy who i bought it from said he used his stock bolt from his 2000 si and it worked fine.
The bolt i am using is
90173-SR3-003 019 004 BOLT, ARM (LOWER) (10X80)
Which is stock.
Any help would be great.
Which is stock.
You'll probably need to get a longer bolt (make sure the grade is strong enough) if you're going to use the Beaks with it. Although, I hope you know the Beaks is pointless when already having the ASR.
I figured it out.
Basically when you purchase an "ASR Subframe Brace" It comes with the brackets, i was having a hard time understanding it.
First: I bolted on the Brackets
Then: The ASR Subframe Brace comes with 4 align key bolts. The ASR gets attached to that bracket and the bracket is what holds the ASR Subframe brace. I screwed those (4)Align key bolts in ASR and Bracket. Then there is (2) more bolts that gets screwed from ASR to bracket again so total of 6 bolts is what holds it.
& I installed my "Beaks bar" as well.
Took me awhile to figure it out.
Confusing but makes sense. lol
arielb1
Dec 18, 2019 11:39 AM
