OBD I and II Automatic Transmission
Will OBD II automatic transmission with OBD I accords?
I did a manual conversion on mine (97) and I'm trying to sell my auto one.
A guy contacted me saying he's getting a 95 accord, OBD I, and he told me it needed a new transmission.
So, will it work?
So, will it work?
It will bolt up w/ no problems. Not sure about whether the TCM from the 95 will control it, need to check part #'s between the two. And the harnesses may be different between OBD1 & OBD2.
Yes. '94-'97 ATs are the same, they are both controlled via the shift solenoids, use the same speed sensor, and shaft sensors. Just make sure to give him the drive plate from your engine. There may or may not be a difference in driveplate and torque converters between different bodies and sub models.
Learned something new today. Thanks.
jdtphotography
Mar 3, 2007 06:54 PM
Civic VTi
Mar 15, 2002 07:21 AM
