bosch. fuel pump
Ive done some research and can't find my answer.does it matter if the inline bosch pump is mounted under car near tank or up front inengine bay.would it stress the intank walbro if I put to close to tank.my plans were to put it under car near tank.thanks
I sure do. Walbro 255 in the tank feeding the Bosch. It is mounted to the bottom of the car by wrapping a piece of sheet aluminum around the whole pump and a thin peice of rubber between the aluminum and the pump. The aluminum is doubled over and secured to the bottom of the car using a few sheet metal screws.
I had a big gauge stereo amp. wire going to the back so I tapped that and power the pump using a relay that is switched on when the stock pump gets power.
