VTEC engaging way too late. Need advice.
Old Feb 24, 2011 | 01:46 AM
Afshin9393's Avatar
Default VTEC engaging way too late. Need advice.
my car is almost completely stock except for mugen head gasket, exhaust, and intake. vtec only kicks in at 6000 rpm. as far as i know, it kicks in at 5500 rpm stock. ecu is p30, b16a from EG6. need advice to know what causes this. thanks.
Old Feb 24, 2011 | 01:56 AM
Russ_Nyce1s's Avatar
Default Re: VTEC engaging way too late. Need advice.
VTEC with a JDM P30 is 5800. Other P30 ECUs have engagment as low as 5600 from the factory.
Old Feb 24, 2011 | 02:21 AM
Afshin9393's Avatar
i see.. the rev cut is 7800rpm? is this correct?
Old Feb 24, 2011 | 02:53 AM
8,200 on second gen JDM B16s. First gen JDM and USDM B16s are either 7,800 or 8k.
Old Feb 24, 2011 | 06:01 AM
Afshin9393's Avatar
then this is either my rpm or ecu problem..
Old Feb 24, 2011 | 06:51 AM
I would say its most likely just a faulty tach. If its still the stock gauge that is. Quality aftermarket gauges are usually spot on. Is the ECU chipped? Most chips get rid of the rev limiter though so you would know if it was or not.
Old Feb 24, 2011 | 07:19 AM
Afshin9393's Avatar
i only did the engine swap etc. the gauge is originally the twin carb. after market gauges in my country cost a fortune. not at the moment. it will be chipped soon. you're probably right. according to the rpm, vtec kicks in at 6000rpm and cuts at 7800rpm..
Old Feb 24, 2011 | 07:44 AM
1320eg6sir's Avatar
ur tach is probly off...
Old Feb 24, 2011 | 01:11 PM
VegasInvasion's Avatar
I'm Huge In Japan
crazihobo
Nov 11, 2008 02:32 PM
b20powereDA
12
Jun 3, 2006 12:35 PM
theslugbug
Jun 29, 2004 09:52 PM
goodwinesi
May 9, 2004 03:22 AM
