My b16a tranny pooped out a spring
I was replacing my passenger side axle and tranny gasket and this spring came out of the hole. Really nothing wrong with the transmission either but a small leak from that gasket, but I think its because its not pushed in all the way.
Sorry to revive this old thread. Cars been outta commission now its back to trying to fix this. I replaced the rubber axle seal you can pick up from autozone. I got one for an ls I believe:
Need help asap. Would be greatly appreciated need to do some delivery driving.
Thanks so much
Thanks so much
The spring is part of the axle seal. It's tucked behind the lip of the seal facing inside the transmission. People tend to jack them up when installing axles. If the spring in your pic is from your new seal, you need to pop the seal out and go buy another one. The seal when properly installed should sit flush with the case of the transmission.
dewoine
Apr 29, 2006 11:31 AM
soHybridized
Mar 1, 2005 08:55 AM
