90 civic si problem
Old Feb 23, 2011 | 04:56 PM
David27's Avatar
Post 90 civic si problem
I have a 90 civic si I put together and after finishing I started it and it is idling ruff and its is popping code 20 electronic load detector, I have done some research and I have checked my motor grounds all are tight and on, I looked in the fuse box under the hood and I don't see the metal plate that is suppose to be the ELD, I am lost so if anyone has ran into this problem and has figured it out or has any suggestions I would really appreciate it thanks.
Old Feb 23, 2011 | 05:56 PM
KINGVEM^^ED6's Avatar
Default Re: 90 civic si problem
my boy had the same cel
but in a ek gsr motor
turned out the wiring to the alternator
was fuct check that out bruhh
Old Feb 23, 2011 | 11:30 PM
David27's Avatar
Ok thanks for the response, but did he have the idling problem or just a lack of voltage going to the alternator?
Old Feb 24, 2011 | 06:26 AM
dephtone's Avatar
This may help you in your troubleshooting:
Good luck!
Old Feb 24, 2011 | 02:08 PM
David27's Avatar
Ill have to check it out thanks for the break down though I appreciate it
Old Feb 24, 2011 | 08:08 PM
macef9's Avatar
Good luck!
Old Feb 25, 2011 | 09:10 AM
dephtone's Avatar
Not a problem. Good luck! I hope you figure out what the issue is.
dwils
Jul 19, 2011 07:28 PM
compprat
Nov 30, 2006 10:26 PM
kewbee7
Jul 19, 2006 07:06 PM
99ek9
Oct 27, 2004 10:26 AM
