painting a polyurethane lip..
Old Feb 23, 2011 | 04:19 PM
buymesomedunks's Avatar
Default painting a polyurethane lip..
so i bought a cheap polyurethane lip off of ebay (just for now) and i've decided im just going to rattle can it. I did some research on google and such but i want to make sure this is the correct way to do this.
1. dry sand the lip with a low grit like 300
2. prime
3. wet sand with a high grit like 1000
4. base coat
5. clear coat
is this correct?
Old Feb 23, 2011 | 04:34 PM
JSPECSIR's Avatar
Default Re: painting a polyurethane lip..
nope.
clean with hot water and tsp,
scuff with red scotch brite and scuff stuff with hot water,
rinse clean and let dry,
wipe with a quality plastic cleaner,
spray with bulldog or other plastic adhesion promoter per directions on can,
spray with a quality 2k primer,
sand, but do not break though to plastic,
sealer,
base,
clear
Old Feb 23, 2011 | 04:58 PM
^^ after primer do i wet or dry sand? or does it matter.
Old Feb 23, 2011 | 05:54 PM
92hondalude's Avatar
dry
Old Feb 23, 2011 | 06:04 PM
What grit
Old Feb 23, 2011 | 06:31 PM
JSPECSIR's Avatar
wet sand with 400 or 600 will be fine.
Old Feb 23, 2011 | 06:37 PM
sc34dc4's Avatar
What color are you painting it? I usually scuff mine up with a red scotch brite pad and wipe down with alcohol. Let it dry and prime/paint it. Wet sand with 800-1000. Then hit up with some clear coat. No need for adhesion promoter like bulldog. The wet sanding process can also be skipped if you want. It depends on how much of a hurry you're in.
Old Feb 23, 2011 | 08:28 PM
Silver. And I don't understand am I suppose to dry or wet sand? Also what is this red scotch brite you speak of?
Old Feb 23, 2011 | 09:33 PM
prelude1897's Avatar
When it comes to primer, I dry sand first with 180 to take out any small bumps and what not, then wet sand with 600
Old Feb 23, 2011 | 09:38 PM
gorillafart's Avatar
if the lip is brand new, with no scratches or body work that needs to be done, then make sure the 2k primer you use is a sealer.... seal it, base it, clear it
do all the steps mentioned above, except use a sealer not a heavy build primer... then go straight into base and clear. no sanding of any primers... only sand/scuff of the bare plastic
Old Feb 24, 2011 | 09:55 AM
wtpracing327's Avatar
Make sure to scuff with a Gray or Red Scotch-Brite pad before applying sealer. If you seal over anything less than 600 grit, sand scratches will show.
Old Feb 25, 2011 | 05:26 PM
JSPECSIR's Avatar
well obviously all these guys are professionals and do this everyday for a living.
plastics must be properly prep'd or paint will not adhere correctly. every rock and bug that hits it will pop off the paint. you cannot just sand and paint plastic unless you like half assing it.
Old Feb 26, 2011 | 06:06 PM
^^ understood. i shall follow your steps jspecsir and thank you.
Old Mar 2, 2011 | 08:47 AM
AccordSeduction's Avatar
post picture of the final result
fernando.
Paint and Body
Mar 2, 2011 08:43 AM
b20quang
Paint and Body
11
Dec 12, 2009 04:35 PM
DynastyRacer22
Paint and Body
Jul 24, 2008 09:42 AM
t3am 83rd
Paint and Body
Feb 21, 2008 11:55 AM
electronb16si
Feb 22, 2007 06:53 PM
