CRX Sir Front sway bar size?
Old Feb 23, 2011 | 04:01 PM
CRX MASE's Avatar
Default CRX Sir Front sway bar size?
I need to replace the bushings on my front sway bar. Does anyone know what size the ef8 front sway bar is?
Old Feb 23, 2011 | 04:31 PM
Tyson's Avatar
Default Re: CRX Sir Front sway bar size?
im pretty sure its 19mm, solid. you are talking about the UK/JDM SiR with B16 right? with balljoint endlinks.
Old Feb 23, 2011 | 04:38 PM
CRX MASE's Avatar
yes, thanks, ive been searching for it with no luck.
Old Feb 23, 2011 | 04:56 PM
Tyson's Avatar
btw, whats the code printed in the middle of the swaybar? it should also be embossed on the side of the bushings.
can you get a caliper and verify its diameter since you have it in your hands?
Old Feb 23, 2011 | 05:00 PM
CRX MASE's Avatar
Not sure, ill have to look next time i have the car in the air.
Old Feb 23, 2011 | 05:01 PM
Tyson's Avatar
you can also ask the uk crx forum.
http://board.hondacrx.co.uk/phpBB2/index.php
i lost my account info and dont feel like registering a fake account just to contact the admins.
Old Feb 25, 2011 | 02:41 PM
CRX MASE's Avatar
The bushing has a letter F on it. Also i can grab the sway bar and move it 1/2 to 3/4's of an inch, is that normal? Im having issue's with my shift linkage rubbing the sway bar and making it hard to shift.
Old Feb 25, 2011 | 03:22 PM
Tyson's Avatar
No, its not normal to move a swaybar.... At all.
What's the deal with your car? Did you add all the front end parts from a SiR on to a US spec crx?
Thanks for the F info, good to know. looks like it IS 19mm. shares the same bushing as the sedans which i know is 19mm, but they are NOT the same swaybar.... the ends are completely different.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/sway-bar-sizes-1894834/
Old Feb 25, 2011 | 06:46 PM
CRX MASE's Avatar
https://honda-tech.com/forums/showthread.php?t=1894834
US crx converted to rhd with all SiR parts. Im guessing bushings are the cause of the movement. I dont think the end links are bad, Just the bushings that mount to the subframe. I know the endlinks are the same as 88 acura legends.
Old Oct 1, 2011 | 07:16 AM
spcrxracer's Avatar
Tyson, I assume you mean the US Civic sedan 19mm front sway bar and the CRX SiR front sway bar ends are different?
The 19mm Civic Sedan front sway bar will still fit on a US CRX, though, correct?
Old Oct 1, 2011 | 07:38 AM
Tyson's Avatar
sedan fits fine.
Larz
Aug 28, 2007 11:59 AM
higgunscrx
May 16, 2005 04:07 AM
phan
Feb 2, 2004 04:16 PM
