wont start, have searched over and over
Old Feb 23, 2011 | 02:34 PM
tacpsi's Avatar
Icon3 wont start, have searched over and over
bouth the car, its a 91 ef sedan 1.5l, ran for 3 weeks just fime, then one day sputtered to a hault. changed plugs, nothing, checked spark, fuel pressure, replaced main relay, everything is fine, car will crank just wont turn over, any help would be great im lost, thank you
Old Feb 23, 2011 | 03:20 PM
Goldo6606's Avatar
Default Re: wont start, have searched over and over
might be ur starter..autozone can bench test it for free..and its pretty simple to unbolt from ur car.
eazy64's Avatar
i say you do a compression test.
Old Feb 23, 2011 | 03:24 PM
KINGVEM^^ED6's Avatar
check ur rotor bruh
Jockone's Avatar
Any codes?
Have you tried to start it with starting fluid? might not be getting injector pulse or injectors could be plugged or something.
00siboy's Avatar
not the starter if its cranking over, check compression
Old Feb 23, 2011 | 03:25 PM
00siboy's Avatar
and noid on injectors
Old Feb 23, 2011 | 05:00 PM
tacpsi's Avatar
yes starter cranks, not a starter problem, havent checked compression, will do, and on the injectors idk, i can build a motor, and boost she **** out of anything but fuel and electrical im cluless for the most part....i will check compression and well see
Active EF
Feb 21, 2015 08:56 PM
Bngo731
Jun 5, 2006 02:42 PM
incredteg3
Jun 7, 2005 03:10 PM
Luserkid
42
Jun 17, 2004 04:39 PM
mugenracer
May 19, 2002 02:29 PM
