Honda Cam Gear Dimensions - PLZ HELP
Old Feb 23, 2011 | 12:16 PM
michaelmikewho's Avatar
Default Honda Cam Gear Dimensions - PLZ HELP
Hey guys. I'm working on a NA J series build and need some help with getting measurements off of cam gears that I don't have on hand to check.
I would like to know the dimensions of the center hole (diameter & depth) and keyway for whatever Honda cam gears you might have on hand; H,K,B,D, or F series. I'm hoping that some or one of these have the same dimension nose and keyway so that I can adapt a pair to the J32 gears; starting from scratch on a lathe is possible but not preferred.
Also, if you don't mind taking the time to do a tooth count and overall diameter measurement, that would be nice to have. I presume there is little chance that any other engine series uses dimensions identical to the J series but it would be nice to be sure before trying to fabricate one from scratch or adapt the center of another adjustable gear to the J series gear.
Old Feb 24, 2011 | 07:27 AM
Default Re: Honda Cam Gear Dimensions - PLZ HELP
Ok, B series is ruled out; keyway is the same but cam nose diameter is just under 8/10ths of an inch.
J Cam nose diameter is ~1.045".
yfz
Sep 27, 2012 01:59 PM
civic-one
Jul 1, 2009 02:23 PM
koa
Jun 10, 2007 12:21 PM
litovi3tboi503
Jan 29, 2007 01:04 PM
