pleae help my eg6
Old Feb 23, 2011 | 11:35 AM
burch-eg6's Avatar
Icon3 pleae help my eg6
hey guys i have a eg6 and i have noticed that there is some oil appearing from the head gasket aeria. it isnt using any oil though i check it every 40-50 miles .would it benfit from a new head gasket ive never seen it before as i cleaned up th engine last year please help me guys .
Old Feb 23, 2011 | 11:40 AM
Former User's Avatar
Default Re: pleae help my eg6
Have you ruled out other more common sites for oil leaks, such as the valve cover gasket, distributor O-ring, or VTEC solenoid (if you have one)?
Old Feb 23, 2011 | 11:46 AM
burch-eg6's Avatar
yeha i have checked them and they seem fine, i replaced the cam cover gasket upon chanign my rocker cover to a spoon style one ,
its definatly head gasket you can see it right in the crevice of the head and block
Old Feb 23, 2011 | 12:20 PM
tlarimer's Avatar
That's usually from a leaky distributor o-ring or valve cover gasket. Did it start leaking shortly after you replaced the valve cover? Chances are the gasket slipped or didn't seal right on installation.
Old Feb 23, 2011 | 12:25 PM
burch-eg6's Avatar
no there was no leak i just pulled up one day to show a buddy under my hood and i noticed the oil stain around the head gasket, it isnt the side of the disrubutor its cambelt side but only at the front, i can see clearly as my engine has been sprayed with high temp paint in silver,
BertDog
Mar 12, 2012 07:19 AM
Adankid
14
Sep 7, 2008 06:14 AM
JdmGizmo
11
Feb 16, 2008 09:32 PM
dohcteg
Dec 23, 2006 12:03 PM
Hans
Mar 11, 2003 06:19 AM
