Suspension & Brakes Theory, alignment, spring rates....
Type r calipers
Old Feb 23, 2011 | 10:27 AM
JMac Dc2's Avatar
Default Type r calipers
Can I fit integra type r calipers on my 98 Gsr? Also can I use my Gsr brake lines with the type r calipers?
Old Feb 23, 2011 | 10:56 AM
roastbeefrichie's Avatar
Default Re: Type r calipers
yes, it'll require an 11" front rotor (fastbrakes.com or re-drilled prelude VTEC rotors)
you'll also need to machine the brackets for clearance
yes you can use your integra brake lines with the ITR front calipers
Old Feb 23, 2011 | 11:10 AM
ITR 23T bracket milling question for dc2 application?
https://honda-tech.com/forums/suspension-brakes-54/itr-23t-bracket-milling-question-dc2-application-2738136/
Old Feb 25, 2011 | 03:12 PM
hfraziers's Avatar
https://honda-tech.com/forums/showthread.php?t=2738136
can DA9 integras use type r calipers? what's procedure for the swap if any?
Old Feb 25, 2011 | 07:45 PM
same upgrade & method for the 90-93 integra DA & 94-01 integra DC (non-ITR)
this applies to 90-00 civic EX & 99-00 civic Si front knuckles also
ITR calipers (stamped 17CL15VN) w/ pads
11" rotors (re-drilled prelude VTEC or fastbrakes.com 11" in 4X100)
machine brackets (link above in post #3)
once the brackets are machined, everything is a bolt-on process
Originally Posted by BrakeExpert
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
futureracecar
Feb 26, 2010 12:12 PM
trepteg
Jun 24, 2009 07:34 AM
gsrpedro
Aug 14, 2007 10:04 PM
Hugo.
Oct 14, 2003 02:11 PM
hoya_10fintec
May 25, 2002 03:39 PM
