black smoke????
so i bought a 93 eg sedan with a b20 swap ls head stock p75 ecu dc header apexi exhaust for $800. it black smokes on hard acceleration in 1st 2nd and 3rd gear then clears out. im think ing to much fuel.......somehow. any help
pulled from random help site via simple google search...
check/smell the oil first and well work from there.... anyone else feel free to chime in of honda specific stuff
Black Smoke: Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor.
How did the fuel get into the cylinder in the first place? Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil as in the white smoke example to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil
gtowni3
13
Nov 5, 2004 02:06 AM
