vafc's are childs play...
Old Sep 25, 2002 | 07:08 PM
JDMchris's Avatar
Default vafc's are childs play...
They max out with 4 digits =X, this is my car when i miss shifted last weekend, portflow valve train keeps me going tho
[Modified by JDMchris, 8:09 PM 9/25/2002]
Old Sep 25, 2002 | 07:09 PM
Stock R's Avatar
Default Re: vafc's are childs play... (JDMchris)
haha.
hope u'r running vtec killers or something.
i don't know how 5 digit friendly the vtec valvetrain is.
TypeR 599's Avatar
j00 crazy
Old Sep 25, 2002 | 07:13 PM
Rob :190:'s Avatar
Default Re: vafc's are childs play... (Stock R)
portflow valvetrain.....
Old Sep 25, 2002 | 07:16 PM
Casey's Avatar
Default Re: vafc's are childs play... ( Rob)
good one chris
Old Sep 25, 2002 | 07:17 PM
DannyITR's Avatar
Excuse my novice question but is the Hondata computer able to completely replace what the v-afc does? People seem to think very highly of Hondata.
Old Sep 25, 2002 | 07:20 PM
Rob :190:'s Avatar
Default Re: vafc's are childs play... (DannyITR)
yes, and more
VAFC=fuel tuning, vtec crossover, nothing more
Hondata=everything an ECU does....fuel, timing, rev limits, etc etc
Old Sep 25, 2002 | 07:22 PM
JDMchris's Avatar
like i said, vafc is childs play.
hondata = owns.
Old Sep 25, 2002 | 07:31 PM
DannyITR's Avatar
So the only differnce is that you need to pop the hood to get at the computer each time you need to tune the car? I guess it doesn't matter since you probably don't want to be playing with the settings while driving anyways (unless you're a stunna and want to look cool). Am I on the right track here? Are you even able to modify the setttings or do you need a special machine/computer to do it? I'm asking because eventually I'd like to build my bottom end up for a 200whp setup.
Old Sep 25, 2002 | 07:35 PM
stevel's Avatar
You plug a laptop in to the box hondata gives you to interface with the ECU. You can run an emulator and tune on the fly with the laptop. Check out the september issue of Sport Compact car. They've got some pics.
s
Rob :190:'s Avatar
depends on which stage you have. stage 2 has to be tuned by a dealer. stage 4 can be tuned with a laptop computer (on a dyno of course), and stage 4 can also tune stage 2....
Old Sep 25, 2002 | 10:16 PM
B2FiNiTY's Avatar
Nuts...
Old Sep 25, 2002 | 10:37 PM
stevel's Avatar
Naahh, street tuning!! that's the way to go. j/k but you could have some different programs too. Like one for the strip (if you were FI you could have a different program for a higher boost level), one for the street (just mild) or maybe even really detune it for good gas mileage for long drives or for smog checks come inspection time. A lot of cool stuff you can do with stage 4. It's all changing around now with the new S200 with different stages. It's getting better.
s
Old Sep 25, 2002 | 11:16 PM
JaeOne3345's Avatar
Default Re: vafc's are childs play... (stevel)
edit..didnt read clearly..dope
[Modified by JaeOne3345, 12:20 AM 9/26/2002]
Old Sep 25, 2002 | 11:18 PM
Rratedcivichatch's Avatar
Default Re: vafc's are childs play... (JaeOne3345)
he said he misshifted.. im guess thats why it went so high..
Old Sep 25, 2002 | 11:34 PM
hybridDC4's Avatar
Default Re: vafc's are childs play... (Rratedcivichatch)
i got a stage 4 setup for sale
https://honda-tech.com/zerothread?id=290376
my buddy has full skunk2 valvetrain with jun 3 cams and he misshifted once and we got a nice readout of 9980 but thats the farthest we saw on the old v-afc
Old Sep 25, 2002 | 11:41 PM
zRd#1's Avatar
hondata is the best... i used to have a stage 4 on my B16 cr-x... worked wonders... no joke. i highly recomend it.
Old Sep 25, 2002 | 11:49 PM
sgT's Avatar
sgT
T portflow valve train keeps me going tho
Valvetrain doesnt save ****.
Your timing belt is what keeps things going and unless its real tight you will
bend something in a situation like that.
Remember, you arent worried about FLOAT you are worried about retarded
exhaust cam timing which causes the damage.
Old Sep 26, 2002 | 12:25 AM
Keyed ITR's Avatar
Default Re: vafc's are childs play... (sgT)
Hope Hondata works with OSX.
Old Sep 26, 2002 | 02:48 AM
pinota's Avatar
sgT, i have my head and block milled.
I have both cams retarded, i´m i taking some risc of running like that without cam gears ?
Thanks,
Pinota
Old Sep 26, 2002 | 06:15 AM
ITR#00-1077's Avatar
Crazy... glad to hear that the motor is still OK... I don't think you'll be doing that much more....
95ITRJDM
Engine Management and Tuning
Apr 25, 2011 12:03 PM
xprm311x
Jan 25, 2006 02:03 AM
specialedition
May 19, 2005 12:11 AM
jun_the_master
Jul 21, 2004 04:53 PM
S-fiend
Jun 29, 2004 02:54 AM
