90 dx crx...auto-> manual
Old Sep 25, 2002 | 06:56 PM
xXx Justin xXx's Avatar
Default 90 dx crx...auto-> manual
what am i forgetting before i start.....and will this all work. using 5-speed tranny from 89-91...89 Si clutch, flywheel. 89 dx shift linkage, shifter, pedal cluster, pedals, clutch cable, mounting bracket for the shift linkage that holds the shifter(89 dx) ecu from 88 dx manual tranny.....
and i was wondering if i can just take apart the center peice in car...take apart the auto set-up and put in the 5-speed boot. will it just mount up in there as if it were made for it. or do i need to get a whole center peice from a 90-91 manual tranny? thanks everybody...
Old Sep 25, 2002 | 07:01 PM
Default Re: 90 dx crx...auto-> manual (bstdvtecRx)
this is some kids car that i am going to try and make a 5-speed. haven't found a tranny yet, but using the rest of the parts from my wrecked crx parts car. and if i am suppling all the parts except the tranny...and doing all the work, what do you think would be a fair price to charge?
and i have changed out all of these parts before on my car sevral times, so i know i can do it right.
Old Sep 25, 2002 | 08:56 PM
the DR.'s Avatar
i dont know what you should charge, but about the center peice, take out the aut shifter and the cable, the shifter will go through the same hold, you might have to drill 2 holes to hold up the stabalizer bar, its pretty straightfoward, make sure you find something to block off the front hole where the auto cable used to go, or you'll feel the exhaust heat come up through the shiftboot.
Old Sep 26, 2002 | 02:44 PM
Default Re: 90 dx crx...auto-> manual (CIVICtypeS)
ok, sweet...i asked acouple of mechanics and they said if they had to supply everything..they said around like 2k. i laughed at em. i told the kid i will supply everything and do it for like 700. only thing i need to know. the axels from a 90 automatic dx crx..will the work in a 89 si crx manual tranny? thanks guys..
Old Sep 26, 2002 | 02:58 PM
wronghand's Avatar
The axles will work.
Bsixteen_CRX
Oct 17, 2008 12:23 AM
wfocrx
Apr 21, 2006 09:11 AM
adam_reiland
Apr 9, 2005 02:05 PM
idriveadelsol7
Mar 23, 2005 02:21 AM
rafimos
10
Jan 31, 2003 09:39 AM
