Alternative way to fill mtf other than through the fill bolt?
Old Feb 22, 2011 | 12:54 PM
Ritchie's Avatar
Default Alternative way to fill mtf other than through the fill bolt?
Hey, I was wondering is there another way of filling manual transmission fluid for a 1997 prelude other than through the fill bolt? Thanks.
Old Feb 22, 2011 | 03:38 PM
minilogoguy18's Avatar
Default Re: Alternative way to fill mtf other than through the fill bolt?
You can do it through the speed sensor, just make sure you put the exact amount, the fill hole is on the side so that you know when its full cause it'll spill out. You could also get a funnel from the auto parts store and put a 3ft hose on it and do it from the top with the hose going down into the fill hole, will just have to remove the intake pipe.
Old Feb 22, 2011 | 07:11 PM
sde780's Avatar
People say you can use speed sensor but I always just use the fill bolt, it's about the same amount of work
bad 91 teg
Feb 1, 2011 04:09 PM
ccc504
May 31, 2010 08:09 PM
thiscivicuser
Feb 26, 2008 06:13 PM
drewbie
31
Feb 18, 2004 09:02 PM
araknis
Apr 10, 2002 03:38 PM
