96-00 civic motor mounts...looking for performance mounts
Old Feb 21, 2011 | 08:03 PM
phelpsj2's Avatar
Default 96-00 civic motor mounts...looking for performance mounts
hey guys i just replaced my clutch on my b16 ek hatch and after brreaking it in the first time i got to get on it, i blew my stock oil filled driver side mount. the engine with normal driving doesnt move too bad but when i got on it, the dash sounded like someone punched it and the whole engine jerked hard. Im looking into some a poly urathane mounts now. im crunched on money so could i just get the driver side for now and upgrade the tranny side later. also how are engine vibrations on the hasport innovative or any other mounts.
Old Feb 21, 2011 | 11:09 PM
ReDHaTcHyGuy's Avatar
Default Re: 96-00 civic motor mounts...looking for performance mounts
the drivers side mount is really only there to hold the motor in place.. the rear mount is the main one that cuts down on movement, and the 2 lower TQ mounts if your are still running them... Ive used the hasport mounts, vibration wasnt to bad.. you def notice it over stock but you get use to it..
Old Feb 22, 2011 | 05:27 AM
hms_2000si's Avatar
Its most likely the rear mounts! My passenger, rear and torque mounts where hanging on by a piece of rubber. I just swapped all my mounts to innovative mounts and deleted the torque mounts.
smokey.23
22
Mar 24, 2009 09:01 PM
whoneedzvtec
Nov 21, 2007 04:13 AM
Boner_Ben
Welding / Fabrication
Sep 29, 2007 02:04 PM
JFG Kevin
Jan 12, 2007 07:33 AM
Tire Monkey
May 2, 2004 05:23 PM
