Whine coming from Belt side of motor (video)
Old Feb 21, 2011 | 03:39 PM
ThatRHDstatus's Avatar
Default Whine coming from Belt side of motor (video)
i have 93 civic with a stock b16a in it, About a week ago i started hearing a whine coming from the motor ever now and again. this week the whine gets louder and its constant. The higher the RPM's the higher pitch the sound is. Its not a belt screech or anything i have heard before. i have video:
http://www.youtube.com/watch?v=IsPdnYxA0lg&hd=1
Old Feb 22, 2011 | 08:06 PM
ktsciv93's Avatar
Default Re: Whine coming from Belt side of motor (video)
alternator pulley bearing?
Old Feb 22, 2011 | 08:09 PM
hmongxcuz's Avatar
belts to tight..loosen it up
Old Feb 22, 2011 | 08:43 PM
Also I took the Valve cover off and looked at the timing belt and to see if anything is rubbing and everything looks good. TBelt didn't feel really tight. Gonna get it professional checked out and I'll let y'all know what is was
Old Feb 23, 2011 | 10:25 AM
redline1219's Avatar
Pull all your accy belts and see if the whine is still there. If it is, I suspect the timing belt is too tight (or tensioner bearing is bad). If not, check to see if your distributor bearing is going bad by removing it and see if its hard to turn by hand.
Good luck
Old Mar 3, 2011 | 09:28 PM
Update. The noise is defiantly coming from the ac compressor or the ps pump. Haven't had a chance to mess with it. Been super busy. But I wanted to fill y'all in. I realize that the noise sound like a bad bearing. I'm gonna do the above suggestion in a couple days
Old Mar 6, 2011 | 04:22 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
AC tensioner bearing.
Old Mar 6, 2011 | 07:45 PM
lsturbo33's Avatar
A stethoscope could help you pinpoint it.
92coupe
Dec 17, 2008 12:08 PM
IP RACING
18
Sep 26, 2008 10:15 PM
accord_2dr
Jan 18, 2008 06:12 PM
slipperyduck
12
Oct 23, 2004 12:05 AM
