HELP: 94 GSR Timing Belt Tension
when i turn off my car i check the belt tension and i know its suppose to be 2 sides tight one not so tight. but that other side feels alittle more loose than it should be. how can i tighten that?
well, if youre worried about it change the tensioner and the belt. the tensioner is what keeps it tight obviously, and can go bad over time. to change it youll have the belt nearly off anyway, so you should change it also, because over time they can stretch.
