turbo gsr w/ type r tranny for sale complete set up.
im selling my gsr motor stock internals with type r tranny i bought new from acura us spec with a ac ramhorn maifold with 60-1 garret turbo ( turbo zero miles brand new never used, complete setup with obd1 computer with honda s300 with boost by gear in it , vented 4 port valve cover with catch can return to block all lines and an fittings new clutch never used installed used 8 pound billit flywheel ,edelbrock victor x manifold with id 1000 injectors 68mm throttle body aem fuel rail b&m fuel pressure regulator , intercooler and tial blow off valve and wastegate hondata intake manifold gasket, and also have brand new in box never used arp head studs for the motor . plus axels and brand new black on black inovatine mounts 85a for the motor for gsr body , complete swap clean frash ready to go easy 450hp plus , also have obd 2 to 1 harnes and an obd 0 to 1 harness from lowcash racing. plus 2 radiators half size one brand new bwr and one used misimoto. motor also has engine harness with it plus motor has skunk2 cam gears installed. ac compressor and power steering pump comes with motor, shift linkage with skunk2 short throw inslatlled , hondata 4 bar map sensor, plus stock obd2 ecu with 2 stock 4 wire used os sensors for those needeing get through emissions also have the stock motors mounts to add with inovative mounts.
looking to sell for cash or trade for complete k swap for my integra dc2
motor is matching number out of my car title to prove it
and have reciepts for everything else including tranny all 100 percent legit stress free expect same if trade.
adam squared
Feb 26, 2011 01:35 PM
AMS MIKE
May 3, 2007 03:54 PM
2point0VTEC
Jun 27, 2004 02:56 PM
