manual tensioner
Old Feb 20, 2011 | 04:48 PM
accordmatt's Avatar
Default manual tensioner
l did the manual tensioner swap. followed all guides for it. for one the manual pulley is larger then auto. doesnt say anything on about different size belt. l put mine on and was driving fine then the belt walked over and ripped but was still on. and its hard as crap to get timing belt on. did l do something wrong? or just something happened?
Old Feb 21, 2011 | 03:09 PM
accordmatt's Avatar
Default Re: manual tensioner
Old Feb 21, 2011 | 04:01 PM
q16racer's Avatar
did you seat the tensioner on the peg bolted to the block?
h22 belt is correct, just takes a little more effort and maybe a little intuitive thinking.
Old Feb 22, 2011 | 04:25 PM
accordmatt's Avatar
yes l sure did l put manual tensioner on just like writeups say. l good guy on here ghostaccord told me l needed a balance shaft oil seal retainer. so gonna get that and install and mine as well do my sk2 cam gears. and yes the belt is a pain in the *** to put on. anyone with other ideas???? just in case
Old Feb 22, 2011 | 04:41 PM
q16racer's Avatar
the ONLY way the belt will slide off the gears is if the tensioner is not seated correctly. The rest of the gears/pulleys are set in place and cannot be moved.
Old Feb 23, 2011 | 05:35 PM
accordmatt's Avatar
how exactly do u seat the belt properly on manual tensioner?
Old Feb 24, 2011 | 04:56 AM
accordmatt's Avatar
bump and how much slack should l have on belt?
Old Feb 24, 2011 | 10:15 AM
Mr.Luder's Avatar
hand tighten the tensioner on LOOSELY snug but enough for it to be able to move up and down. put the belt on counter clockwise starting from the crank. rotate the crank counter clockwise about 4 teeth and you'll see the belt start to tension. tighten the tensioner down and wala. the belts don't have to be on super tight but to loose and i'll walk off.
f20beme
Apr 8, 2015 07:47 PM
the boogler
Mar 25, 2012 06:18 AM
black94lude
Jan 5, 2010 04:04 PM
ragnarok0mega
Sep 16, 2009 08:35 PM
JJexpress
Feb 18, 2009 10:38 AM
