anyone know the thread size??
Old Feb 20, 2011 | 02:04 PM
jinxd12's Avatar
Default anyone know the thread size??
does anyone know what size thread the tappet nut and bolt are on a gsr/b16 rocker arms? i need to buy a tap so i can debur the threads to run my bolt in and i can not find anywhere the size of the threads..any help would be great!
Old Feb 20, 2011 | 02:16 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: anyone know the thread size??
I don't know the pitch unfortunately. If you can get your hands on a thread
pitch gauge you'll have your answer in no time. Pretty cheap and handy to
have around. They will be included in any decent tap/die set, or you can buy
them separately.
Old Feb 20, 2011 | 02:18 PM
vartok's Avatar
couldnt you take the bold to a hardware store and say i need a tap for this bolt?
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
it's probably a 5 mm fine thread 1.0 pitch but don't quote me on that
Old Feb 20, 2011 | 02:20 PM
you have the bolt? try several fine thread metric nuts on it until it screws on easy, ace usually has the best selection of metric nuts and bolts as does fastenal if you have one it's probably going to be a fine if i remember right
Old Feb 20, 2011 | 02:33 PM
jinxd12's Avatar
i went to ace actually and they didnt have ****...i was there for 45 min checking every single nut and bolt..the tappet nut and bolt is so fine its hard to know...i need to know so i can order a tap and fix my problem!
Old Feb 20, 2011 | 03:50 PM
jinxd12's Avatar
come on honda tech..help me out??
Old Feb 20, 2011 | 08:39 PM
jinxd12's Avatar
ttt????
Old Feb 21, 2011 | 04:33 AM
BryanM.'s Avatar
Resident Gearhead
You would already have your answer if you just use that thread pitch
gauge I posted. Easy to find and cheap.
Old Feb 21, 2011 | 10:34 AM
jinxd12's Avatar
I went back to ace and to home depot and I asked for a pitch guage and they handed me a tool to see if my bolt would thread into...so idk what u are saying easy to find...maybe ill just take iit to a machine shop tomorrow
Old Feb 21, 2011 | 10:59 AM
Red_Army's Avatar
don't ask. go look for yourself. just because they work there doesn't mean they are all that knowledgeable beyond where it might be.
they are very easy to find.
Old Feb 21, 2011 | 03:22 PM
honda.lioness's Avatar
If forced to bet, then from the torque specification and the fact the nut takes a 10 mm socket, I would put it at M6x1. But you are going to have to check per the suggestions above.
Old Feb 21, 2011 | 03:34 PM
92lxsleeper's Avatar
i second the m6x1.0 as a guess
Old Feb 23, 2011 | 02:07 PM
jinxd12's Avatar
isnt 1.0 not a very fine thread...like a 2.5 is very fine these threads are SUPER fine
Old Feb 23, 2011 | 02:20 PM
dem0nk1d's Avatar
them separately.
Yeah as long as it's not a Harbor Frieght Tap n Die set.
Old Feb 23, 2011 | 02:25 PM
BryanM.'s Avatar
Resident Gearhead
I said decent
Old Feb 23, 2011 | 02:48 PM
the old cuss and throw set, thats what you do when the soft unhardened taps break off in an expensive part
Old Feb 23, 2011 | 02:59 PM
twocross's Avatar
The M6X1.0 is the right size due to the 10mm socket reference. If it has the 12mm socket bolt head then it would be a M8X1.0. I bought the taps and corresponding drill bits recently from Sears/Craftsman.
lando griffin
Honda Civic (2006 - 2015)
Apr 10, 2009 09:54 AM
dkrex001
Jan 15, 2009 10:29 PM
MidShipCivic
Welding / Fabrication
Nov 30, 2006 11:35 PM
DB8_TEG
Oct 24, 2003 04:03 PM
