H22a top dead center
Changing water pump and timing belt. Lined up cam marks, took timing belt and balancing belt off now noticed that crank mark isn't lined up. Not sure if I'm top dead center? What do I? Any ideas? Help is greatly Appreciated!
Thank you for your reply! Can I just put the timing belt back on and line it up TDC with out the balancing belt on. Then line up the balancer pulleys and put the balancer belt on?
