Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
95 odyssey ignition problem
Old Feb 20, 2011 | 12:15 PM
ssdjoey1904's Avatar
Default 95 odyssey ignition problem
ok so my ignition has been starting to act up lately and kind of gotta jiggle the key to get it started,well today it finally bit the big 1,it will crank no problem and if i give it gas while im cranking it then it will revv but shut off as soon as i let go of the key,i was thinking it was the ignition switch since i had the same issue on my impala,i was trying to bypass it and run a wire from the power side of my battery to the power of the dizzy,but not sure which wire is it so does anyone have a wiring diagram? thanks and hopefully i can find out to make sure its that vs something else
Old Feb 22, 2011 | 11:36 AM
evil_ryu's Avatar
Default Re: 95 odyssey ignition problem
not sure if this helps?
Old Feb 22, 2011 | 04:11 PM
dtapia's Avatar
why screw around with this just replace the ignition switch and be done with it. ?
Old Feb 23, 2011 | 07:02 AM
evil_ryu's Avatar
^^ was thinking the same thing, my odyssey shut down on me on the hwy one time because of the ignition switch. everyone in the car sh1tted bricks.
Old Feb 23, 2011 | 01:45 PM
Targa250R's Avatar
be professional
It's almost guaranteed to be a bad electrical contact assembly on the end of the ignition switch.
You're not going to get it running that way, you're just likely to mess up something important.
Instead of half-assing it with a bunch of hackjob wiring, just buy a new ignition switch contact assembly and replace it.
Part no. 35130-SX0-A01, list price is $65.20 from Honda but you can find it at several online parts dealers for $48 or less plus shipping.
Old Apr 2, 2011 | 08:55 PM
RA5_Prestige's Avatar
it was one of the recalls. call honda. ignition switch.
turbo-crx
Jan 22, 2009 06:46 AM
saemoonyang
Nov 18, 2008 02:37 AM
dizzyroc88
Nov 18, 2005 07:28 AM
SickWitIt2.0
Jan 22, 2005 11:27 AM
BlkGSR
Mar 7, 2004 06:28 AM
