Transmission & Drivetrain Gearboxes, Differentials, Clutches
5th gear problem
Old Feb 20, 2011 | 10:46 AM
Tito559's Avatar
Icon2 5th gear problem
Hey guys I have ? And a problem....I have a b16 tranny runs smooth no grinds or nothing only problem is 5th gears pops out...so a guy at a shop told me it was low on tranny fluid..so he added som for free..drove smooth with no problems for about 2 days..then the same thing 5th started piping out again...my question is can I go some wer to repair te tranny or is it just better to buy a new one???
Old Feb 20, 2011 | 11:22 AM
Honda Bull's Avatar
Default Re: 5th gear problem
Does the trans leak fluid?
If it is mechanical damage to the trans, you'll probably be looking at $250-$350 in parts to fix it 100% plus labor which varies from place to place. B16 transmission go for at least $400, if you can find one.
Old Feb 20, 2011 | 01:44 PM
Tito559's Avatar
Well I had no leaks ti the guy filed it up but I gues he over filled it and leaked the excess other than that no leaks ...:/ ...
Old Feb 20, 2011 | 05:23 PM
Honda Bull's Avatar
Then it probably is damage to the physical components.
Could be a synchro spring missing and it'll be under $10. Or it could be gear, sleeve, hub, shift fork, etc. leading to $300+ all causing it to fall out. No way to tell until it's opened up and you can visually inspect it.
Old Feb 20, 2011 | 06:19 PM
Aquafina's Avatar
I'd go ahead and have it fixed. A used trans is good shape is getting hard to come by now. If it was low on fluid, the 5/R sleeve assembly and top MS/CS bearings will likely need to be replaced.
Old Feb 20, 2011 | 06:51 PM
Tito559's Avatar
Yea I calls a shop and I'm taking it tuesday morning 6 flags tomorrow ...... Well honda bull thanx for all the info and aqua aswell I'll take it thnx guys
Old Aug 2, 2011 | 08:57 AM
JAHREDGOMES's Avatar
same prob
bigboom
Apr 12, 2010 10:34 PM
indtegra
Nov 5, 2007 07:22 AM
bboyfreeze
Mar 26, 2007 06:41 AM
VTECcnIT
Feb 25, 2006 12:12 PM
jchanth
Jul 4, 2004 03:06 PM
