Do I need another tune? B16 nitrous 75 wet shot
Old Feb 20, 2011 | 07:59 AM
bigchili's Avatar
Default Do I need another tune? B16 nitrous 75 wet shot
Hey hondatech I just installed my nitrous kit and I need some suggestions.
So here are the stats of my motor
B16a stock bottom end
Gsr head
Skunk2stage2 cams
Skunk cam gear
Skunk2 valvesprings and retainers
Ngk 7aparkplugs/bluewires
Itr replica header
Now I just got my car tuned on chrome I'na chipped p28 and I'm tuned really well for all motor but I just installed a nitrous kit and it's ready to spray A 75 wet shot but my question is...
Do I need a new Ecu system? Is it necessary to retune my car if I just swap in colder spark plugs and run the 75 shot? What do you guys think? Plz only respond if u know about nitro...
Old Feb 20, 2011 | 08:48 AM
boca's Avatar
Default Re: Do I need another tune? B16 nitrous 75 wet shot
u need to tune it asap if you want the motor to last
Old Feb 20, 2011 | 09:43 AM
bigchili's Avatar
what ecu do i need b.c i need to have 2 different map settings right? one for nitro and the other for all motor?
Old Feb 20, 2011 | 10:59 AM
Ryank327's Avatar
You don't need another ECU you just need a tune. Just call your tuner and they will tell you what to do.
Old Feb 20, 2011 | 11:53 AM
bigchili's Avatar
i know i can do that
but my question is my ride going to feel like crap with the new tune if i dont use the nitrous? do u know what i mean?
Old Feb 20, 2011 | 12:08 PM
ashb82's Avatar
I think you can use this, have it when you spay to takes out timing and add fuel
http://www.moates.net/font-size-12ti....html?cPath=69
Old Feb 20, 2011 | 12:32 PM
racebum's Avatar
there's another way around the timing that would/should come out. it's with octane. if you run 110 octane gas 50/50 with pump you should be safe. should be on copper #7 plugs, possibly #8s depending on how the 7s look. you also could rig up something like a 3-5 gallon fuel cell and use it strictly for drags. the high octane approach will net you the fastest time at the track as well
Old Feb 21, 2011 | 07:02 AM
7rrivera7's Avatar
Get a second tune on a commercial product like eCtune or Neptune (stock chip) using their dual map feature which can even trigger the NOS solenoid by RPM, gear, etc.
Shady420
Jun 30, 2008 08:08 PM
RZA24
Jan 2, 2007 02:40 PM
DrivinVtec
Feb 3, 2006 08:15 PM
sickerhatch
Jun 28, 2005 09:31 AM
Audio28
Dec 7, 2002 11:23 AM
