Help piecing together missing a/c components
I'm hoping someone may be able to help. I have a 94 Civic that was involved in a low speed front end collision. The previous owner hit a pole around 15mph. It was enough to damage the radiator support, the condenser, condenser fan and the a/c lines. The support was replaced but the damaged a/c components were not to keep cost down. They removed the damaged parts without replacing them. Looking at the car now, the compressor is still there along with the drier. What parts would I need to complete the system? Any help would be greatly appreciated. Thanks.
Find a new/used condenser ,condenser fan,and the A/C lines. Then charge the system to test the A/C motor. Should work fine unless they damaged more removing it.
