Advice Needed - Do I need an adjustable fuel pressure regulator
Old Feb 20, 2011 | 12:08 AM
nicolaselias's Avatar
Loved
Community Favorite
Default Advice Needed - Do I need an adjustable fuel pressure regulator
HI everyone...
My current setup on my F20B2 (SOHC non-vtec) is just the usually I/H/E..
I have a custom Bisimoto level 1.5 cam ready to install, but I can't do that without dyno tuning shortly after..
So, I have my APEXi SAFCII installed (I cant use a chipped ECU with auto trans) and the prospective dyno tuner is telling me that I will need an adjustable fuel regulator to tune properly...
However, I am not sure seeing as the fuel pump and injectors are currently stock.. I also can't see myself maxing out the current stock injectors with my only major mod being the cam..
Do you all think I need the AFPR? If so, what brand do you recommend?
Old Feb 20, 2011 | 01:42 AM
slomofo's Avatar
GDD Member
Default Re: Advice Needed - Do I need an adjustable fuel pressure regulator
No.
Old Feb 20, 2011 | 09:58 AM
Loved
Community Favorite
I appreciate the advice slomofo, any chance you can elaborate? I have been told that these piggyback units are good at leaning out the mixture but not so good at making it richer, which is why he suggested the AFPR...
In my mind however, I didnt expect to need THAT much more fuel pressure based on the minor mods...
Old Feb 20, 2011 | 11:16 AM
phootbag's Avatar
Poke holes in the vacuum line going to the regulator until the desired pressure is achieved.
Old Feb 20, 2011 | 05:49 PM
Loved
Community Favorite
But what happens if I wanted to then lower the pressure? This seems like a pretty irreversible step..
Why would I need to adjust incoming fuel pressure myself? Shouldnt the ECU compensate for that and do it automatically? Especially considering my modification is not that heavy at all..
Old Feb 20, 2011 | 05:53 PM
phootbag's Avatar
Old Feb 20, 2011 | 07:39 PM
Loved
Community Favorite
While I appreciate the smiley happiness, care to elaborate on why I would and would not need an AFPR?
When would it then be considered necessary?
Old Feb 20, 2011 | 09:02 PM
fasterthanueg's Avatar
You do not need a regulator also you don't need that safc, Maby if you were boosted it might have some use.remember Function over fashion and good luck.
Old Feb 20, 2011 | 10:32 PM
Loved
Community Favorite
So how do you propose I tune after I install my Bisimoto cam without using the SAFC?
It has nothing to do with fashion, but as I said, I cannot use a chipped ECU, so I need a piggyback solution....
So, you all tell me that I don't need the regulator but no one is offering any reason as to WHY... Care to share some knowledge concerning that? When will it be needed, when will it not?
Old Feb 20, 2011 | 11:18 PM
TexasRedCD5's Avatar
+1 to a reason. I am having this issue also
Old Feb 21, 2011 | 03:16 PM
Loved
Community Favorite
Answers are greatly appreciated... Anyone
Freemananana
Feb 22, 2014 03:40 PM
jaredvabeach
Aug 6, 2008 07:38 PM
IntegraGSR-Turbo
Feb 27, 2007 07:16 PM
92civy
Oct 13, 2006 09:12 PM
TypeR714
Sep 21, 2002 09:02 AM
